Hi all I try to greasing my roof mechanism but roof not stay on the top
When I stop pressing the red button it going slowly down .
I tried In different position but is not stey.
Probably hydraulic pomp is not strong enough or what.
I not turn off the ignition.
What is correct of this two :
Raise the roof about halfway, close to the neutral balance point; turn off the ignition to stop the roof at this position. Be alert; after several minutes the roof may sink down to the closed position if not stopped near the balance point.
or:
its easy to remove the roof liner
open the roof half way keep the engine running.
there are three screws on each side and if i remember correctly three at the front.
This removes the plastic trim and then the carpet just comes away
i cut all of the ballows (plastic) away from the switches with a small pair of cutters.
remember that the roof will go back down after 7 mins if you dont touch it.
good idea once youhave the liner off is to allow the roof to close so you can see the exposed switches in action.
Premium Member 2004 SLK200K
Option 2 - You need to keep the engine running to maintain the roof in the half way position ...
If your roof is going down with the ignition on , check the pressure relief valve/screw is tight , other than that you may have a leaky hydrolic cylinder .
The 170 roof behaves different from the 171... 170 starts dropping as soon as you release the switch. Make a broomstick per John's specs it will work fine on 170.
Premium Member 1998 SLK230
On a R170 if the engine is running & you let go of the switch the roof will stop moving & stay where ever it is for 5 minutes (maybe less mabe more) then the pressure is released & the roof will move by itself.
I agree with the broomstick method.
