Hi there, I intend to replace the roll bar covers (black part, front side) on my SLK (R172) by covers with small openings for correct wind deflector placement in between. Any suggestion to remove the old covers?
Thank you,
Jan
Thank you,
Jan
No tools, just brute force, these are bear to get off. The front and back are simply clicked together. I know, I've replaced mine with 'silver' ones.
Won't this leave the rears with the holes for the wind guides?
You need the rubbers to fit in the fronts too. They will hold the wind deflector.
Thank you,
Jan
First please update your location and vehicle (Put Looking!)(year?: 1996-2018, model?: 32, 43, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
On a smartphone: http://www.slkworld.com/new-members-introduce-yourself-here/330737-how-update-your-profile-post-intro-smartphone.html
