1 - 20 of 30 Posts
Registered 2007 SLK55 AMG
Does this sound weird to anyone.
I have full electric mirrors for adjustment on the center console with the round knob and buttons but the button to retract the mirrors is missing.
I figured it would be all or nothing in that area, was this actually optional?
They fold from the outside but not retractable electronically.
See your owner's manual if you haven't for such a feature
I don't have that....let's go look :D
Nor do I, thats not a pic from my car but another SLK 55.
well you sure that pic is from a slk55 and not a sl 55 as an example?
From Sean
You don't need Parktronics for this feature, but you do need the correct mirrors
Check your mirror adjustment switch (near the gear lever). If the middle button has a picture of a folding mirror then you have the feature - if not then you don't.
Simple enough to retrofit - you just need the correct mirror switch and two replacement mirror 'frames' with the power folding mechanisms.
They come up on evil bay now and then - the mechanisms from a R230 SL can be made to fit as well.
New, they are fairly pricey.
No coding needed unless you want the autofold on lock-unlock convienience options. If no coding is carried out they will work from the new switch only.
I've done this myself - take a look here
Cheers
Sean
Registered 2012 SLK350
Electric folding mirrors is a specific option for most markets, you can have electric with memory and not folding.
option 500
171 500 OUTSIDE REAR VIEW MIRROR LH AND RH FOLDING
Premium Member 2007 SLK55 AMG
I have that, I thought it was standard.
I'm gladvi have it or it would be a pain to put mine in the garage :surprise:
Discussion Starter #16
I can't believe it doesn't have it.
Who sells powered mirrors and does not have them retract.
Then again who in their right mind would order this car with the power windows and NOT the retractable.
I don't get it.
I don't get it.
Let us know if this works :D
But i am sure you need the option added in das
option 500
Discussion Starter #19
option 500
Could the hardware be there but not the coding for it to work?
I doubt this because no button but I don't know.
1 - 20 of 30 Posts
