Registered 2005 SLK350
Please help. I check all fuses good.
Swap all relays. Replaced crankshaft sensor. Still same problem. Check spark on one plug, good. Check fuel and fuel rail, no pressure, no fuel. Plan to verify if voltage is available at the fuel relay in back of trunk later. What else can it be? Is there a inhibit inertia fuel switch for reset? Thanks.
Great news! Question for you: how did you measure the fuel pressure?
