1 - 17 of 17 Posts
Hi
My apologies I have been on here for 7 years now since I got this car and done a few fixes myself with you experts advice to others.
My roof was fine, then it developed an oil leak and my mechanic replaced the pipe and oil, the roof hasn't worked since. The console light flashes, the windows don't move and no noises heard.
He now thinks the roof latch is faulty.
Can anyone please help? I'm one frustrated owner.
I can see other threads but not for this issue.
I'm in Chester UK
Thanks in advance
Stuart
First please update your vehicle (year?: 2003) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘vehicle’. Info in your garage does not update your profile.
Want to ‘like’ or thank’ someone’s comments? Use the ‘like’ button to the right or the ‘Thanks’ button, bottom right of any post you like. This saves you having to comment or use the 'quote' button so we know who you are asking or replying to or referencing.
https://www.slkworld.com/vehicle-data-card/67706-free-how-get-free-datacard.html
I already posted this but here it is again. If the light is flashing then some sensor(s) is not responding correctly.
The first step requires a Mercedes scanner (U$100 Autel Diaglink is fine) and I have posted the proper switch settings below.
Once you determine what is wrong, then you need to correct the problem, by then I should have the post that contains what is where.
Do we have an indexed archive somewhere ?
ps if your mechanic does not understand the .pdf, perhaps you need a new mechanic.
Welcome from Canada :smile:
Please update your vehicle (2003) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Welcome from Wirral, England.
(year?: 1996-2017)
in your profile as it helps the members answer your questions which usually are based on that information.
edit your ‘location’ and ‘vehicle’.
The reason that we ask you to update vehicle/location details
is to save repeating the same information every time that you ask a question.
Also, this site is truly worldwide. That can matter when you ask for help and information.
Are you looking for a bonnet, or a hood, a boot, or a trunk? Makes a difference.
Driving on the left, or the right?
We have a free to enter monthly competition.
Entry is normally open from the 1st to the 15th of every month. You simply post a reply with 3 photos.
After the 15th we usually open a poll for members to vote on their favourite.
Here's the main thread:
https://www.slkworld.com/rotm-submissions-voting/
New members are welcome to enter (and they win too!).
March winner (an R170) joined Summer 2017 and had only 6 posts at the time of winning.
Newbies can win.
Voting is open for the 2018 September Ride of The Month.
PLEASE NOTE :- Voting closes on September 30th.
https://www.slkworld.com/rotm-submissions-voting/529435-vote-here-september-2018-slkworld-com-ride-month.html
Really useful links (thanks to ixions cataloguing)
https://www.slkworld.com/general-discussion/354330-links-toparts-assemblies-technical-data-locations-parts-slks.html
https://slk-links.neocities.org/ Includes diy videos.
Spare parts: https://slk-links.neocities.org/EPCLINKS.HTM
A brief guide to the forum and how to get the best from it:
https://www.slkworld.com/new-members-introduce-yourself-here/439993-new-wondering-what-do.html
There's a link to R170/171/172's do it yourself threads under the pic below.
Some useful tips in this section for new and prospective owners.
Worth knowing are reset adaptive learning, check list, Spring is here and what is the SmartTop.
https://slk-links.neocities.org/BUYING.html
The UK has an active meet scene.
Here is a taste of what is coming up and a couple of links to past events to whet your appetite:
https://www.slkworld.com/united-kingdom-region/437417-uk-new-members-spring-2018-a.html#post3587793
First, is the blind inside the boot in the correct position?
Sometimes the switches don't connect correctly.
Tip:- have the engine running whilst using the roof testing issues.
it uses a lot of power and can drain the battery.
Have a read of this:
https://www.slkworld.com/slk-r170-general-discussion/75882-vario-roof-diagnostic-aid.html
https://www.slkworld.com/slk-r170-general-discussion/12451-slk-230-hydraulic-roof-actuator-repair.html
Handy link in general.
https://slkworld.com/r170/home.htm
As said, a scan should narrow things down.
Have your mechanic check his work. It sounds like the luggage partition switch is not in place.
Premium Member 2009 SLK55 AMG
Stuart
Will the roof lower manually?
Will it unlatch manually?
I'll page our experts.
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
@Australian
The system has safety devices.
An example, if the windows do not lower, the roof will not operate.
Has the system been checked for power?
Sometimes it is something very simple that stops the whole process.
Hi Stuart, welcome from Barrhead, Scotland. :smile:
Discussion Starter #15
Fixed
Hi All
Thanks for the welcome and the suggestions on how to fix this.
In the end it turned out to be the roof catch. Bought one from a salvage agent we use in work off a rear ended smashed SLK and Dave at MD Motorcare fixed it.
Now all I need is the sun!
Stuart:smile:
Hi All
Stuart:smile:
Glad it worked.
ps Don't forget to add year to SLK 230 details.
see earlier post for how to.
Premium Member 2012 SLK55 AMG
Welcome from Gloucester UK.
I’m glad you got it sorted:wink:
1 - 17 of 17 Posts
