Registered 2005 SLK200
Hi I am replacing the fuel pump and I encounter following problem.
The pump is out of the house and outside the tank, but is still fixed in a plastic cylinder, with a filter at the bottom and the electrical connections and fuel connection at the top
How do I get the pump out of that cylinder? Sorry for my rude question but I can't find a solution and I'm afraid of damage.
Thank you in advance for your advice
This addresses your "in a plastic cylinder" comment. In all likelyhood, they say that entire unit is replaced/can't buy parts separately.
Till others show up:
Reactions: Squishband
Ok thanks, now i understand, i was misled by online shops in belgium Brandstofpomp VDO A2C53044857Z Electrisch, Benzine — Bestel nu!
thks,
The module that holds the pump can be taken apart.
With a little force, the top part will click loose and you can easily disconnect the connections from electricity and pipes from the pump.
But now a different problem arises, when I tested the pump and she is ok, hopefully part number 50 is broken, otherwise all the work would be for nothing
