1 - 11 of 11 Posts
My driver's side door started to make a binding, popping noise when I opened it. Thought it was the hinges so I greased them but no improvement. I took it in to Mercedes and they told me that the door stop needed to be replaced. Searched the 171 forum but did not find anything. Has anyone replaced the door stop before? Thanks.
Door hinge bolts
Hey Jeff. Looked through all of the threads. From my inspection, seems like the two "bolts" through the hinge and into the door are recessed into the hinge (can't really see without taking the entire door off, which I was trying to avoid.). Do you know if they are torx head bolts and what size they may be? Thanks. Ken
you talking about the bolts that secure the door to the body?
trying to get an idea of what i am searching for :D
see what you need here?
bolt is m8x35
The bolts that attach the door hinge to the door. They might be torx heads. I will need to use a mirror to be sure but I will check.
Can't see any attached thumbs. Is it cuz I am using Chrome?
pics in my post 5
i use chrome and have no issues
you on pc or smartphone?
I sent you email
On a PC but on a corporate LAN. I will check on my PC at home to see if I can see the attachments. Thanks!
I sent em also to your email on record
1 - 11 of 11 Posts
