1 - 20 of 37 Posts
I've searched the threads but didn't see it. It's that time for a new battery and I will change it myself. I've looked and there are several choices for battery replacement but I would rather ask SLK owners for recommendations as to the best bang for the buck. It's my 2006 SLK55. I extended the battery life somewhat with a good trickle charger but think it's just that time. What are your recommendations ?
Thanks, Frank
Frank,
Here are a few threads. I went OEM using M-B Roadside Assistance and it cost me $165. I have heard of folks getting aftermarket ones for as low as $100 or so with a special deal.
http://www.slkworld.com/slk-r171-general-discussion/21319-oem-battery-lifespan.html
http://www.slkworld.com/slk-r171-general-discussion/25273-2006-slk-280-battery-size.html
The only thing I would tell you NOT to do is take it to the Dealer to have them replace it. They will charge you the $165 for the battery and then another $120 or so to put it in. Call Roadside Assitance and they'll come to you and install it for free. (If you've spent $150 or so at a Dealer in the past year or so.)
Best Wishes,
Thanks, Frank
Anyone know how much the stock battery weighs? I'm considering a battery by Deka (same as Braille I believe).
649MF Premium (54.5lbs)
9A49 Intimidator (58.5lbs)
9AGM49 Ultimate AGM Series (58.5lbs)
On my kit car, I will be using a Lithium Ion Battery
(acid battery weighed about 11kg, Gel battery (red top 25) weighs about 7kg, Lithium Ion battery weighs just over 1kg)
With the above battery weights, bear in mind this is on a car with VERY few electrics, but I have provided them, as a weight comparision between battery types.
Is there an opportunity, for a (big enough for a SLK - or multiple smaller ones) Lithium Ion Battery.
To save more weight, on your SLK?
Thanks, Frank
I also have a 2006 55 and replaced it with the Bosch Part #78DT-850B. ( this is a top post group 78 battery). A couple of others in the treads used this battery.
The books say a group 48 fits, but it doesn't on the 2006 55, you need something under 11 inches long like a group 46.
Took about 5 minutes to change myself and cost just under $110 to do.:Beer:
My eyes!!!!!!
Yes, I did the same for my SLK55 AMG. I drove my SLK55 AMG to a local PEP BOYS and they helped me measure the battery and I bought one made by BOSCH and the size was "almost" the same. I remembered that the "height" was off by just a little bit. But it still worked fine. They do have one with the "EXACT FIT", but were out of stock and I could not wait for a few days for them to order it. They refused to install it for me as they usually will do for no charge. I guess they were scared they will do some damage. But I knew how to do it anyway and it was not all that difficult. I did bring with me a "jumper charger battery" to connect it to the SLK BEFORE disconnecting the defective battery so that the "memories" in the SLK are not lost. Anyway the first Bosch battery I got from Pep Boys was defective and died a couple of months later. I took it back to PepBoys and evidently they knew and had a lot of returns and they just swapped out for a brand new one right away. No problems since then.
On my SLK280 I was no where near a PepBoys. So I went to a "Discount Auto Parts" in the "Deep South" and bought one that was the "exact fit" and I put it in without any problems.
Both of the above were a lot less expensive than OEM at MB dealer.
Or you can have MBrace roadside assistance get one for you (still less expensive versus at the MB dealer). I did not use this option due to I was under a tight schedule so I just drove to a local PepBoys and got one.
Good luck....
I'm going to use the Bosch battery if I can find one at a Pep Boys. Thanks for everyone's input.
Discussion Starter #13
Battery
Thanks guys, appreciate your input and help. I installed the Bosch battery this time to see how it works out.Y)
DAS/STAR Registered Owner
I also went with a Bosch one - straight swap size wise...
Cheers
Sean
PS – check out http://www.slkworld.com/united-kingdom-region/31725-east-midlands-rabbit-chase.html for info on the possible East Midlands ‘Rabbit Chase”
Mods so far...
Airscarf Retro-fit http://www.slkworld.com/general-modifications-r171/27470-project-airscarf-starts-here.html
Alpine double-din touchscreen head unit with Bluetooth, Nav, DVD, reverse camera and iPod with a ‘Small’ sub in the boot
Mercedes Genuine rear Windscreen
http://www.slkworld.com/general-modifications-r171/32951-new-windscreen-one-back.html
Display& steering wheel integration for the head unit.
Digital Climate control panel, Sun sensor and Pollution sensor fully working
http://www.slkworld.com/general-modifications-r171/30240-climatronic-retrofit-digital-climate-control.html
Hat-shelf mounted solar charging panel
Rain Sensor for Auto-wipe retrofit
Various coding changes to the Instrument cluster – see below
AMG Aluminium gear change paddles instead of the buttons
http://www.slkworld.com/general-modifications-r171/31587-amg-aluminuum-gear-change-paddle-retrofit.html
Facelift SLK Antenna http://www.slkworld.com/general-modifications-r171/32272-facelift-antenna-tick-otherwise-known-two-minute-mod.html
Harman Kardon speaker upgrade – All 11 !!
http://www.slkworld.com/general-modifications-r171/31530-hk-speaker-upgrade.htmlCustom dimming LED DRL’s http://www.slkworld.com/general-modifications-r171/32992-looking-drls.htmlLED’s… in various places…[x] - Map…[x] – Dome…l [x] – Number plate…[x] –Side…[x] – Puddle http://www.slkworld.com/general-modifications-r171/33120-leds-were-all.html
Full blown TPMS…
http://www.slkworld.com/general-modifications-r171/33263-tpms-retrofit-its-started.html
Auto Dimming rearview mirror with integrated GPS Speed Camera detector BEHIND the glass….
http://www.slkworld.com/general-modifications-r171/35096-my-solution-dimming-interior-mirror-look-away-if-you-dont-want-see-things-getting-cut-up.htmlPower Folding mirrors… http://www.slkworld.com/general-modifications-r171/33942-folding-mirrors-making-start.html
Designo style Alcantara head lining / A Pillars and various other bits….
Johns 3rd brake light gizmo
http://www.slkworld.com/general-modifications-r171/15456-johns-3rd-brake-light-adapter.html
Mods in progress
Parktronic retrofit – nearly all the bits are here….. Just need the main loom now….
…soon this section will be empty …!
Mods on the wish list
Maybe a Smarttop....
Illuminated Sills – I have a cunning plan…
Coding Mods… http://www.slkworld.com/slk-r171-general-discussion/31073-my-adventrures-star-diag.html
[x] - Enable those pesky phone buttons on the steering wheel - FINALLY DONE - WOOHOO
[x] - Enable Auto-wipe – done
[x] - Add temperature display to the lower MFD - done
[x] - Enable tyre pressure Loss Warning - done
[x] - Enabled Folding mirrors – done
[x] - Enable Gallons Remaining in the MFD – done
[x] - Enable Cornering Fogs - done
[x] - Enable both rear fogs - done
[x] - Enable Alarm 'chirping' – done
[x] - Enable TPMS display in the upper MFD – done
[ ] - Enable Highline TPMS – proving tricky!!, but we have some great brains on the case….
You should be able to go to pep boys or of course, mercedes
fyi, most of the posts in this thread is for the slk 55 amg which uses a more powerful battery.
Frank,
Best Wishes,
Just replaced mine at MB dealer. Your right $165 battery $75 labor With 2Year full repalce no proration or labor
What kind of battery do you have? I have to replace mine soon,
for everyone to answer: and this is off topic but where can I get the affalterbach emblem on the shift knob installed? Im planning on doing a DIY if its possible.
:eek:fftopic:
Thanks Ronalyn
1 - 20 of 37 Posts
