Has anyone ever had the need to remove the luggage cover in an R170. One bolt is visible but removing it did not make it possible to remove the cover. Thought I would ask for help before removing any of the plastics in the trunk.
On the Pre-FL the entire mechanism can be freed with two 10mm bolts on the left and right. No panels.need to be removed.
Premium Member 2001 SLK320
Should be a 2 minute job.
Same for pre-FL and post-FL R170 . I've taken it out on both my cars.
Can you post a picture?
