Hi I thought I had fixed my window problem but it got stuck about 1/2 inch down
on my passenger side (UK).
Anyway I removed the door panel and window switch which was ok when tested so I bought a new door module and it worked just about to have it coded.
I used vaseline on the rubber to hook the panel back on as it made it easier also I took some pictures which may help others under taking this job.
