removing cd player from slk 320
3870 Views 3 Replies 3 Participants Last post by  pattypat
I am trying to find out how to remove the cd player from the trunk of my 2001 mercedes slk 320. I only found one screw attached to the bracket and after removing this it would not come out. Anyone have suggestions.
Thank you,
Founding Member/Sergeant-at-Arms/Moderator
See less See more
there is another hidden bolt, It's been awhile, but I remember having the same issue.
Check this link
removing cd player
Thank you, I will have my husband try this over the weekend.
