1 - 8 of 8 Posts
Registered 2003 SLK200
I saw a post recently, that Jeff had reinstated the photos in it, on the rear wheel bearings.
Can I find it again? Nope:(
Anyone point me in the right direction?
Yes, I have done a search:laugh:
TIA.
I'm at appointment
Will look on my return
Search
Jaysonm
Registered 1997 SLK230
TIA.
If you are looking to replace the rear wheel bearings I would strongly recommend the Pelican Parts how to article. I followed these instructions and whilst not exactly a piece of cake it enabled me to succesfully renew both sides ok.
Sent from my SM-T710 using Tapatalk
of no use to OP
Thanks Borris.
I have seen that. I just need to get the hubs off. I have a guy that will do the bearing pressing for me.
Yes that bit is the challenge... I used a (very) large bearing splitter clamped on just behind the hub and wound it out as per the Pelican Parts how to by using the wheel bolts. Had to move the splitter a couple of times and it did put a burr on a couple of the bolts but I just ran a die down the threads to clean them up afterwards.
The worst part of the job was actually getting the wheel bearing retaining circlip in after the new bearings were in place. But once I bought the right tool for the job it was ok. Also I ground a little metal of the outer circumference of one of the removed bearings so I could use it to carefully tap the new one in after putting it in the freezer overnight and applying a small amount of heat to the hub with a hot air gun.
Good luck.
1 - 8 of 8 Posts
