Does anyone know how to remove and replace the Auto Dim Rear View Mirror on a 2001 SLK 230???? Please help.
Moving to the r170 general discussion section from the homepage
nimbusgb stated in his thread:
http://www.slkworld.com/460937-post10.html
Welcome from East Sussex
Replacing is fairly easy.
The unit has a short wiring tail and a connector tucked behind the windscreen frame trim panel.
The mirror is removed by grasping the stalk firmly and rotating it clockwise or counterclockwise about an eighth of a turn. Its a tight fit but that is all that holds it on. Draw out the wiring and connector, disconnect, connect the new one and reverse the process, tucking the wire back up under the valance.
5 min job
