My bet is little spring that holds the brake shoes in place, it comes away from the backplate, you have to take the disc off to see it, mine has done this but got caught against the disc and squeeled like a pig for miles, proper embarrassing
I found this one:so I really need something like a Haynes manual in PDF to reference so where can I get one as Haynes seem to only do their online autofix option for the SLK?
This is the online equivalent of a Haynes Manual, without the stripdown/rebuild, here's what they have to say about it before you purchase.As far as we all know, ALL Mercedes manuals are proprietary and are ONLY available from MB at a cost substantially higher than $50.
Anything else is either incomplete or a pirated copy or probably both. Just so's you know.
Depending on hownloud it is, it could possibly be the half axle boot. Mine made a faint clicking sound but it was only audible while I was actually under the car and happened to turn the rear wheel to get access to a different part of the inner wheel. There's no way I would have heard it while driving. That being said, good luck finding s replacement without replacing the whole half-axle. I have yet to find one and had to bandaid mine with a universal that wraps around. Either way, good luck.I'd planned on going out for a cruise yesterday in what's was the nicest day of the year so far but as soon as I started to drive I could hear a click, click, clicking sound coming from the rear of the car. It was constant and speeded up when I started to go faster so I turned around went home and parked up.
This morning on checking to see if it was still there, starting up was fine but when I put the car into reverse there was a bit of a judder as if the brakes were binding which stopped as soon as I started moving. After backing out I put the car in to drive with no issues and drove some 2 or 3 miles at various speeds with no issues so I pulled off the road on to a siding. I then reversed back and forth for some 30 yards with no issues about 10 to 15 times but on the last time driving forwards the clicking noise at the rear started again so I drove home. The clicking sound remained all the way, getting quicker the faster I drove so my question is.... what could it be?
My thoughts are CV joint / drive shaft.
Sounds like a stone in the tyre or trapped in the break calliper. I would want to check the calliper, especially if reversing cleared it.I'd planned on going out for a cruise yesterday in what's was the nicest day of the year so far but as soon as I started to drive I could hear a click, click, clicking sound coming from the rear of the car. It was constant and speeded up when I started to go faster so I turned around went home and parked up.
