I've decided to take the pulley upgrade/tune plunge. From what I've read, Eurocharged is the way to go.
181mm vs 185mm
397 bhp 407 bhp
388 lb-ft 401 lb-ft
17.5 psi 22 psi
Looks like to me it's worth the $300 premium to get the 185mm.
Any thoughts or experiences or options?
Registered 2012 SLK250-gone
never got into pulley changes. You can try the Camaro or Corvette forums. They talk about modding superchargers over there.
181mm vs 185mm
397 bhp 407 bhp
388 lb-ft 401 lb-ft
17.5 psi 22 psi
I use an ASP 178mm on my 32
The 181 or 185 have a couple concerns. A/F ratios can get whacky quick so you would want a wideband gauge unless you dont mind an engine rebuild. Also may need a fuel pump upgrade, possibly injectors as well. Colder plugs may be needed.
Regardless of which pulley, will need a pulley saver kit from Needswings and some kind of cold air intake setup. Needswings makes a nice one.
Thanks for the input. I was definitely going with the Pulley Saver kit. However, I had not considered the other aspects regarding the 181 and 185 set ups. I really do want a "bolt-on" upgrade. Guess I'll be doing a little more research.
may want to lurk crossfireforum.org as a much more active mod community
the srt6 is the same drivetrain as our 32's
