Hello. This is my first post here and am glad to be a member as I just found the site. I own a 1998 slk 230 and am having a problem with it. I am getting ramdom misfire code for cylinders 2 and 3 and also had code for camshaft position sensor which I replaced. I changed plugs and cleaned maf. Engine has a constant miss and lack of power at higher rpm and is very slow to pick up rpm when at idle. Any thoughts on this ?
Jay
Jay, moving to r170 general discussion
Thank you,
Moderator/Founding Member
