1 - 8 of 8 Posts
My wife's 01 SLK 320 will intermittently say it doesn't see the Magazine in the 6 disc changer. It may work in the morning and then not in the afternoon. I removed the fiber plug and power plug Friday and plugged it back in and still says the same thing. Any ideas? I do hear it trying to read the magazine so I know it's getting power.
Mine was doing this too last year. The factory uses a white lithium grease to lube up the mechanism inside, but after 10+ years the grease drys out and actually binds up the mechanism.
I took it out of the car completely (just a couple screws holding it to the bracket and it pulls out) and brough it inside. I then took it apart far enough so I could get the cover off and access the internals. I then took a q-tip with some WD-40 and used it to wipe off all the old dry white grease. Take your time and be careful. I was able to work the mechanism back and fourth by hand too and could feel the resistance ease up as I cleaned up the old grease. Finally I made sure everything was lubed with nice clean lubricant (I can't recall what I used...maybe just more WD-40) and put it back together. Getting the big "ribbon style" connector that goes to the peice where the main connections are back in place is a little tricky, but pateince prevailed.
My CD changer has been working flawlessly for over a year now. Well worth the 2 hours or so.
Well, I took it all apart, greased all the spots with new lithium grease that looked like it needed it and low and behold all is good. Thanks for the help.
Paul, check under usercp as for the 'sent' choice being checked on pms
Sweet
I just fixed mine the same way! Thanks but after hearing the cd sound so good I wonder why my radio sounds bad.
1 - 8 of 8 Posts
