Mercedes Dealer told me this has become a common Problem.
Over time the Plastic gets brittle and cracks if you "bump" the hose.
The break happens where the hose is clamped to the plastic. It is reinforce with a copper insert but is still able to crack and drip.
Over time the dripping can ruin your radiator fan motor.
This is an easy fix.
Dealer wanted $460 to repair it.
BAP auto parts store $100 (in stock)
Ebay Brand New Genuine OEM part $68 (had to wait a week to get it)
30 minute of my time.
Hope this helps.
SLKman:tu:
Great job man.
I had the same problem with my SLK200 and bought a new tank. It costs about 70$ in here. I changed it in the garage and now it works fine.
I found this thread after I noticed white residue on the expansion tank for my '04 320 while I was cleaning under the hood and promptly broke whatever fragment of plastic was still holding the barb on.
I reinserted the brass nipple and took it for a test drive. Although it wasn't going to blow out, it was leaking pretty good without the bit of crust it had.
Pelican had an OEM tank for $96 (it's where the washer fluid is warmed smh) so I'm waiting for it to get here. Meanwhile, I thought I'd share a tip:
As a stop gap measure I took about 3/4" of teflon tape, wrapped the brass nipple 3 turns and put it back in the hole. It's doing the job so far. YMMV.
THIS IS NOT INTENDED AS A REPAIR.
Because I can't edit the other post for clarity: washer fluid warming is a secondary function. It uses heat transfer from the coolant.
