1 - 20 of 21 Posts
What would be a reasonable price to ask for 4 brand new slk 17" alloys with tyres - direct from the factory?:)
I'll have a set in around two weeks time.
Thanks in advance
If you update your profile, i will tell you:
Front alloy wheels: 17x7.5" ET42
Wheel part number: MER A17240136029765
Rear alloy wheels: 17x8.5" ET36
Wheel part number: MER A17240137029765
Alloy wheel finish type: Mercedes Titanium Silver
I'm assuming that these wheels will also fit onto a 171/172 slk too.
The wheels are available with four brand new tyres from the factory.:)
Sadly Woolly has passed away
If you don't sell them, and you intend driving your R172 in winter, they're worth keeping to put winter tyres on. With the SLK being RWD and fairly light on the back end, winter tyres make a helluva difference.
That may be an option.:tu:
I can't see a 172 owner wanting these, however they may make a nice upgrade for a 170/171 owner.:)
Stock ET for 350's are f36-r30, sport is f37-r30. Would the 172 wheels cause any fitment problems on a 171? I've never upgraded wheels, so I have no idea. Also, what tires are on these wheels.
Thank you.
Premium Member 2013 SLK55 AMG
Lockheed 1971
Hi, I may well be interested in purchasing these for my R171 350.
Do you know that they will definately fit straight onto the car?
Perhaps you could pm me asap so that we may discuss.;)
Regards
TonyS3
Lockheed
Sorry I should have done my research first.
Looking into it it would appear that the offsets on these wheels are too large for the R171 - tho if anyone can advise who knows about these things I'd be grateful as I know very little.
Also R171 has 12mm bolts, R172 has 14mm bolts, I think this could be a dealbreaker.
Again if anyone can advise please jump in.
Regards
TonyS3
aka John
So those ET's are pushing the edge of what you'd want to do on an R171, but I bet they would fit. There are also two different bolt sets for the R172, one's longer than the other (for the 16' wheels evidently) Suspect that these would work on a R171 but with the longer R171 bolts. If they were 18's, you'd prolly be over the edge.
Looks like these are close to what come on the W204 these days - so if you are intent on selling them, that's probably a safer market..
another mercedes model. standby and i will try to get you the 'real' name
aka John
Take a look at WhiteRabbits post - at the very least you'll need some specialized bolts to use these on the R171/170. The shaft diameter on the R172 is 14mm, and on the R171 is 12mm. I strongly suspect you could get bolts that would work, but you are starting to needless complicate things I think!
Also, Jeff's spot on - the W204 is the "new" C-Series.
1 - 20 of 21 Posts
