?My ir door sensor unlocks car.
Had aerial off car so had to use it.
yesdoes indoor switch lock/unlock?
nop, also the radio work fineFuse 8 in trunk/boot.
check out our R171 diys for fuse location and one of those has good photo.
I take it you have not removed aerial?
That has same effect.
no interference and the battery changed twiceAnything likely to be causing RF interference in the area?
Simple things like remote senders for weather stations can cause problems if the batteries start to die and the sender goes off frequency.
I checkedon the Fuse 8 and it was dead, i replaced it, but it gone immediatelyHave you replaced fuse 8?
You have a short in the opening circuit is my guess.I checkedon the Fuse 8 and it was dead, i replaced it, but it gone immediately
What is the problem?
