I just checked today that on my 2007 SLK 55 AMG I bought used, the owner put 245/35/18 tires at the front while the stock front tires should be 225/40/18.
They are 20mm wider up front but that probably isn't too much of a worry.
However, the 245/35/18 tires make the front end about 1/8" (4.25mm) lower than spec.
Is it something I should worried about? The rear tires are the correct spec. size of 245/35/18 though. Thanks.
i would put 225s back on the front and save the 245s as spare rears. i have 255 on my rear and you probably could go up to 265
Premium Member 2005 SLK55 AMG
Hi All
Yes keep front as standard the AMG is low enough at the front , The rears I have 255's with no problem & will be going up to 265 for the next set.
Cheers
Andy
Sorry to revive an old thread, but are there any rubbing issues with running 245/35r18 up front?
First please update your location and vehicle (year?: 1996-2017, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
