1 - 9 of 9 Posts
I appreciate the warm welcome to the site. I've been poring over the details on the brake rotor options for my SLK55, but I've been unable to ascertain all of the details.
From what I've gathered so far, I have either a 4 or 6 piston caliper setup on the front. However, I have yet to figure out how to determine which one. It looks like I might have the option of reverting over to a single-piece brake rotor, if I have the 4 piston.
I've found this thread:
http://www.slkworld.com/slk-r171-class-diy/164314-brake-rotor-turning-limits.html
My vehicles data card shows the following info:
Identification number: WDB1714731F085701 9
From that, I'm of the understanding that this is what my rotor parameters are:
FRONT ROTORS:
171.473
New: 32mm
Wear Limit: 30mm
Wear Limit for Service: 30.6mm
Is there a quick means of determining what my options are? My local MB shop gave me a quick quote of $1,800 for just the rotors. However, I'm not entirely certain the correct option was offered, since this was over the phone.
Because of this, I'm hoping to see if there are any alternatives out there.
I believe since you are prefacelift, you have the 6 setup.
Have you checked your brochure?
Cause they knew I was going to upgrade
hello all this is my first comment,still dont know how to work this site properly ,haha. anybody correct me if im wrong but I read somewhere that apart of the costs like you mentioned it was to avoid the squeaking many people complained about
Chuck
Please update your location and post an introduction thread as in my message to you
Please update your location in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ .Your profile is NOT updated in your ‘personal garage’.
We want to welcome you properly so post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
I appreciate the quick response, as well as the subsequent post with links. Correct me if I'm wrong, but my understanding is that I only have 2 options for replacements at this point. I've got the standard OEM's, or I can look into the R/B product in the link below. If these will work, that's a roughly $700 reduction in cost.
Two-piece rotor (Open Slot) - MERCEDES CLK55 AMG FRONT 05-06
I knew I would be expecting increased maintenance costs. However, $2,300.00 for the front brakes alone was a bit of an eye-opener ( kick in the pants ).
1 - 9 of 9 Posts
