Hello from Poland !!
I have a strange problem with my SLK 200 Kompressor.
When i put my foot down(kickdown) i can feel lack of power, another thing, O2 sensor parameters. When the throttle is fully open, long term correction is +25% in one moment...it means that system is lean :( short term corrections are correct. I have already change MAF. O2 sensor was changed 3 months ago.
There is only one error in OBD reader - P0410.
Please help i run out of ideas.
Regards
New members should be aware that the 'New Posts' link next to the 'Search' link top right of the info bar is a great way to see all of the posts you have missed since you were on the forum last. Remember to click 'mark forums read' under quick links when you leave.
Thank you,
Moderator/Founding Member
Premium Member 1998 SLK230
Hi Again.
I've discovered that throttle on the kompressor is opened all the time. It doesn't move at all. Is there a possibility that throttle is dead ?
