Hello and happy Thanksgiving everyone!
I too have the dreaded "start error" hot start problem (SLK230 won't start until it's cold).
Things I've already tried include:
-checked all fuses
-replace CPS (crankshaft position sensor)
-re-solder k40 relay module
-replaced k40
-replaced fuel pump
-replaced ignition transponder coil
One thing that I've discovered, which has made it possible for me to live with this problem, is that when I turn the engine off, then immediately turn the key back to 2nd position (electronic components powered on, but engine off) and leave it there, when I return to my car, I can start it every time. However, if I remove the key, even for just a few seconds, then try to start, it reads "start error" and I get to sit around and ponder life for atleast 1/2 an hour.
Upon research, I discovered this thread: http://www.slkworld.com/slk-r170-general-discussion/25705-start-error-dash-readout.html
However, I can't figure out where OP's 2nd photo is taken. Anyone have a clue?
Here's the image: http://i38.photobucket.com/albums/e103/JFRALBUM/SLKfilcapteurarbreacames.jpg
I'd greatly appreciate any advice or suggestions!
Thanks!
Want to post a picture? Start a new thread or make a post, click ‘edit’, click on the ‘paper clip’ or ‘advanced’ and/or ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’!
Post your vin in the Vehicle Datacard Request section to get a datacard (options on your car). http://www.slkworld.com/vehicle-data-card/
Moving to R170 General Discussion
New Members Introduce Yourselves is just for that. More R170 members will chime in now!
Since you're in the US, why not take the car to a MB dealer and get them to carry out the recall upgrade that's required and see whether that sorta out the problem?
Sorry, I don't know where the 2nd photo shows, but I'm sure someone helpful will be along in a minute to help.
Welcome to the forum, by the way, from not so sunny South Wales.
