1 - 2 of 2 Posts
Here's confirmation of a worthwhile tip, my son found for me, on an earlier thread stashed way down somewhere on one of the Merc forums.
Central Locking not activating with key fob:
1: Don't Panic...!!! (Like I did omg)
2: Check to see if Interior Light is working. If not, check Boot/Trunk Light is
working. If not, chances are its the fuse.
3: Read Page 189 of the SLK Owners Manual and/or
4: Pop the bonnet and locate black plastic fuse box on the left hand side rear,
in the engine bay.
5: Squeeze cover lug and open black plastic fuse box lid and remove cover.
6: You'll see on the reverse of the cover the circuit identifiers label.
7: Circuit 9 is what you want to check.
There is also Circuit 26 - Yellow 20Amp for the Central Locking but in mine this
was okay.
8: Circuit 9 is a Red 10Amp fuse for the Interior (Roof) Light, Boot Light, Horn,
and Alarm Activation.
9: Pry this fuse carrier out.
There's a tool for this in the vehicle took kit. I used long nose pliers.
10: Check the fuse. If blown, replace with similar Red 10Amp fuse.
Spare fuses are usually contained within the fuse box.
11: If this resolves the issue give huge thanks to the forum contributors that help
to keep us on the road and out of the clutches of the money grabbing main
dealerships that would happily charge £60+ for a STAR diagnostic check
bollocks to them.
12: Have a great day.!!! Hopefully out in the car with the top down. Yeehaa...
Founding Member 2006
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
1 - 2 of 2 Posts
