1 - 15 of 15 Posts
rear speakers
thanks for the replies it seems like a lot of work to fit them. i will have to rethink what iam going to do.
rear speakers
only had car 2 weeks the wife will kill me if i start ripping it apart. i think i will wait a bit longer.
Does any one know what size speakers will fit in the hole ?
Im guessing, that bose put a non standard size in, but if i adapt it i can fit 6.5" ?
The holes were designed for rear facing speakers ,you need to adapt the mounting area as in the link I previously posted to fit standard speakers .
6.5" speakers will fit
Below is a picture of a factory rear speaker.
I have CDT speakers in my car....they make 6.5" shallow mount speakers....BEST SPEAKERS I HAVE EVER OWNED.. alot of competition guys use this. I used 6.5" subwoofer/woofer in rear...and 6.5" Mid/HIGH in the front..and then used Clarion tweets (I like clarion tweeters) in the front doors... I Then tied it all together with a punch Amp...
Rear speakers are ran at 2 ohms @ 180 watts per channel
front speakers are ran at 4 0hms but ran parralel with tweets so probably dropped ohms to 3... so would roughly put 140 per channel (at that ohm)... so when buying speakers pay attention to your ohms
Then everything is ran thru High def pioneer radio, with flash drive.
sounds much better then stock... make sure you also use your crossovers...the amp will have a High / low crossover for your fronts and rears (lows cross for rear, high cross for front)... then since your tweets are tied into your fronts, use another crossover in your parrallel run AFTER your front speakers going to your tweets to run them at a higher frequency....
hope this helped some.
I'll bump this. I'm thinking about doing this. But it looks like A LOT of work!
There's not that much work man. I put subs in mine and it was simple!
Are you sure it was simple? Do i really need to do all the things on the guide that was posted?
And is it possible to fit 10" subwoofers in the holes? With some modification? Regards Tim
10 inch subs in back of 2002 SLK?
Is there a easy to do this. I'm willing to cut into metal. Is there room - depth wise? Do you access it from trunk?
easystbob,
Want to post a picture? Start a new thread or make a post, click ‘edit’, click on the ‘paper clip’ or ‘advanced’ and/or ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’! If Iphone pics, you need to rename any additional pics as Iphone names its pics all the same,image.jpg.
Post your vin in the Vehicle Datacard Request section to get a datacard (options on your car) free. http://www.slkworld.com/vehicle-data-card/
Registered 2011 SLK300
Geez, ou guys are looking for something easy and then you want to put in 10" woofers and cut out sheet metal. As soon as you get away from stock, it's going to get incredibly difficult to get it right. I have the stock speakers in my car and they are balanced and sound great, even with the top down and the volume up.
Premium Member 1998 SLK230
I just installed a Jensen 7 inch pop up screen head unit and a Jensen 65 watt amp (in the trunk) in my 01 SLK320. I also installed rear speakers in the provided mounts. Had to "adjust" the speaker mounting screw holes but that's it. I'm changing them now though cause I want woofer, subwoofer only. I did manage to blow the fronts...whoops! Bose speakers didn't handle it.
Cheers!
1 - 15 of 15 Posts
