Had my 02 200k in for a major service where I was advised it needed a "rear brake overhaul".
Not being the most mechanically minded person, I'm unsure as to what this entails, is it merely change of discs/pads, or a full strip down and rebuild of the brakes?
Any help or advice would be extremely appreciated :burnout:
And a happy new year to ya'll!
Hard to say -- ask the mechanic what he saw? Typical brake service is just replacing pads, maybe rotors, and maybe flushing the fluid -- all of which are routine operations. The usual symptoms that would call for a more extensive brake overhaul are finding fluid leaking out of the calipers, or one or more sticking pistons in the caliper.
Registered 2009 SLK200
Rear brake overhall could include rear brake pads , rear brake discs , rear in board brake shoes and adjusters / spring kit !
Merc include all spring / adjusters / spring retainer's etc included in the brake shoe kit if my memory serves me correct !
Plus brake flexy hose pipe which are common to crack / split .
Doubt callipers as callipers either work / bind ie dont release or leak ! :tu:
