1 - 20 of 21 Posts
Hello all,
My left rear ABS sensor had no reading with ABS and BAS/ESP lights on permanently for a while now. I replaced the sensor which made no difference. I did notice it was not held correctly in the rubber bung so thought maybe the weight of this had broken the connection of the harness/hub to wire. I took it to an autoelectrician who had a look, agreed it was the harness rather than the sensor (apparently it should look like a castle or lego but mine is flat) but states he can't replace it. I'm trying to find a connector on eBay but can't find anything. Does anyone know the official name for this to help my search?
Matt
rpm sensor maybe? part 95?
this is from a 320
post your vin for yours
Hi Jeff,
That's very useful thank you. Unfortunately the car is being stored at my friends for 2 weeks now but I'll get the VIN as soon as I get it back. I replaced part 95 and it made no difference. It is the attachment this goes into (i.e. the connector on the car lead side, rather than the sensor lead side). Much more difficult to try and replace!
still post your vin for your datacard when you can
in USA we have our vin also on our insurance card, etc :D
I've looked through all three schematics and two use part number A0125458628, the other doesn't show the connector. Found one on eBay. Now just need to find someone who can reliably fit it! Thanks for your help Jeff.
fyi that part number is not for a r170
Standby Matt
Let me reread the thread to see what i am looking for besides datacard :D
Ok here is your datacard. let me see what you now need or tell me :D
rpm sensor right?
Here is the only sensor i found for the brakes
So no speed sensor for rear wheels per epc
your datacard does not show a chassis number
170444
My datacard also does not show a chassis number
that part number is not shown in epc
but like you found, spend $4 and see :D
Mercedes Wiring Connector Plug Terminal A0125458628
At least you got your datacard...sorry....
Discussion Starter #19
Just to conclude this story - that part made no difference whatsoever. It transpired to be the reluctor ring in the hub. You have to remove the rear drive shaft so I took it to a garage. Picked it up this morning, what a difference! The ECU must have been upset by the warning lights because the power and gear shifts are much improved. Very happy.
So what was the problem with reluctor ring? Damaged somehow or worn?
1 - 20 of 21 Posts
