1 - 11 of 11 Posts
Does anyone know of parts for the R170 that cross reference from other cars? If so this thread could save some members money.
Founding Member #2
Tslick may, as he has the R170 & the Crossfire.
EPC will cross reference other Mercedes that the parts are used.
Len
I did some research and came up with this. I can't guarantee the information, but it may help someone as a starting point.
Transmission electrical connectors (leaky ones)
Electrical connector shell (with 2 O-Rings)
MB 2035400253
Crossfire 68021352AA
Electrical connector insert (with 1 O-ring) goes inside of above connector and can also leak
MB 0015409981
Crossfire unknown
Trans Fluid
MB 001989680310
Crossfire 05127382AA
Siren/Alarm
Mercedes#A171 820 25 26
Crossfire# 56038724AB
Plastic lock pin (for dipstick hole)
MB 1409910055
Crossfire unknown
Wiper pivot-to-cowl grommet/seal/isolator, black
MB 1708240098
DC 5101283AA
Wiper arm-to-pivot nut cap, black
MB 0008240249
DC 5101489AA
Washer reservoir/tank
MB 1708690320
DC 5096729AA
Lug bolt locks, set of four
MB Q6408113
DC 82208313
Transmission check/fill tube lock
MB 1409910055
DC 5093746AA
Oil filter cap assembly, with filter and o-rings
MB 1121800710
DC 5114263AA
License plate light assembly, with lens and bulb
MB 2308200256
DC 5099804AA
Relay Control Module
MB #170 545 03 05
Mopar #5099007AA
Lock cylinder key housing
MB # 2024600904
chr # 68001655aa
Rear brake pads non SRT
MB 0034202720
Mopar 5126300AA
All oem CAI air filter
MB 112 094 0304
Mopar 5098424AA
My heater blower had been broken for 3 years, I kept getting bad resistors that werent comparable for.whatever reason, and ir eventually killed the blower too.
Luckily, the blower motor and resistor from a w202 c-class is a.direct swap, they are identical parts. I picked up both for $30 total and now have perfect functioning climate control after 3 years.
Per ardua ad cineris.
Pse
R170 PSE seems to have a number of part numbers.
I have seen the following:
170-800-05-48
170-800-04-48
170-800-08-48
But don't actually have a reference p/n, since I have never had one in my car.
Anyone know what the different numbers mean? Any of them build standard, so alternatives?
And, of course, an alternative source, to break the expensive bottleneck that currently exists?
I need a remote control pump for SLK 230 1998 Kompressor.
A/ I need a part number for this item, I purchased one from Germany which has turned out to be the wrong one, these are asking for the correct part number
B/ Any other help, one for sale, other that may replace
thank you
Brian
thank you
Brian
Brian, always better to make a new thread rather than post at the end of a 6 year old one?
post your vin
get your free datacard
get the part you seek
or go look here
https://slk-links.neocities.org
1 - 11 of 11 Posts
