Hi all,
With 128k miles on the clock, I went to change the motor mounts on our USA 230SLK. I bought the lemoforder 2540601 (which the actual mount was molded " Boge" ) and 2022402517 Rein from AutohauzAZ.
When I removed the (USA)driver side last night, it looked the same as the 2540601, with a thin rubber shield. The mount I removed had the Mercedes star logo, and was stamped "2022402617" The Lemoforder box was labelled "cross reference 240 220 2617...Which should be for the left side, according to the info I find on line...
The Rein mount that is supposed to be for the left drivers side didnt come with the rubber shield/cover...
I am the 4th owner, records do not indicate mounts were changed, but date code indicates 2001...
Help!
