Hi Everyone. I have a 1999 SLK 230K and I am replacing the mirror adjustment switch. The car is fitted with the switch for folding mirrors and I am replacing it with a standard switch. They have different connectors. The folding mirror switch has 9 pins whereas the standard switch has 8 pins. My guess is that the extra pin is for the folding function. Can anyone tell me if the wiring colour codes are the same for each switch? I.e. Pin 1 on one switch has the same colour wire as pin one on the other switch?
Update: If the reason for swapping the original for a standard switch + a secondary switch for the powerfold is due to availability of an R170 PF Switch ..
IT IS the same switch that is found in the W140 S Class and there are loads of them kicking about on UK eBay, obviously I canna speak for the Philippines tho 🙃
Here you go. It's still available and really not expensive. Certainly no good reason to mess with the wiring. The sockets for the switches are totally different as I'm sure you appreciate.
A170 683 06 08.
A170 683 06 0
A170 683 06 08.
And while you are at it, maybe you need to solve the issue of removing the handbrake grip? The problem is largely due to the lump on the metal stem at the button end. It's the politest way I can put it. A couple of old feeler gauges along both sides will help getting it off. I then slit mine along the bottom so I can pop it off in a second if I wish. The alternative is to cut the thing off and buy a new one of course.......
Mission accomplished at least until I can get a new bezel. I have my mirrors working with a standard switch but obviously no fold function.
Related Threads
Mercedes SLK World
1.3M posts
78.9K members
Since 2006
A forum community dedicated to Mercedes SLK owners and enthusiasts. Come join the discussion about your R170/R171/R172 SLK, or AMG performance, modifications, troubleshooting, maintenance, and more!
