Had a little issue the other day after giving the car some heavy right foot from almost cold ( yes i know bad boy) - it redlined before change down but them sulked a bit - lost kick down and clonked when coming to a stop. Sounded like gearbox trying to change down but not having it.
It still drove but very under powered and still a bit clonky when going from P to D etc - so did the ECM reset and its been fine since.
Been "advised" the car slipped into limp mode as the harsh use when cold sent the ECU into a confused state. Basically though it was in the wrong gear hence ECU reset - now changes gear perfectly - smoothly - quietly and all power is returned.
No dash lights - no EML - But it does not have one so it wouldn't.
Is this even possible - hard to believe the car got confused
SLK230 1998 .
I find the system to be "dumb". if you do anything outside of it's programmed limits it will do that. cold shouldn't really matter, but it must have confused a sensor somewhere.
I have a new conductor plate and everything, yet sometimes if I spin a tire coming out of a corner it goes straight into limp mode...
SLK230 1998 .
First please update your location and vehicle (Put Looking!)(year?: 1996-2018, model?: 32, 43, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
On a smartphone: http://www.slkworld.com/new-members-introduce-yourself-here/330737-how-update-your-profile-post-intro-smartphone.html
Premium Member 2004 SLK32 AMG
Now THAT is sad ?
