Hey! So I really want to buy this SLK down the street but the check engine light is on. Im going for a test drive and I'm gonna try and hook up my scanner to it. What error codes do I need to look out for so I dont buy into a ton of problems.
what generation slk? r170? r171? r172?
then i can move your thread to the appropriate section
Registered 2000 SLK320
The 320 engines are fairly reliable, CEL usually caused by faulty electrics, usual fault codes relate to,
Secondary air,
Camshaft sensor,
Crankshaft sensor,
Missfire, random or a specific cylinder and plug.
The K40 relay can also cause CEL to come on.
Try and get a list of the fault codes then look up on the OBD2 website.
There are a lot of faults that do not cause the CEL to come on so there may be quite a list stored in the ECU.
Regards Stuart.
Im picking it up tomorrow because the carfax was so good. Its actually a 230 slk. The owner took it in to the dealership to get serviced regularly. Im going to get the codes probably after I have the title but so what I'm down to get one of these back to mint condition. 3 owners and alot of replaced parts. Any codes that should keep me from buying it?
When you get it
Update this please
Vehicle: 2000 SLK 320
To 230
320 was 6 cylinder
230 4 but kompressor
