1 - 12 of 12 Posts
Hello dear car owners SLK W170. My name is Ilya, I am from Moscow, Russia. I own a beautiful car, but experiencing some difficulties with the operation. The fact that Russian forums Mercedes-Benz is very little information on the technical part of the device. My problem is this: my car SLK 200 W170, M111 engine, manual transmission, aspirated engine, not the compressor. The problem with the ABS. The machine is equipped A0225450232 control unit, to find a Russian failed. I found a similar A0225450432. Speedometer started to work, but gives a cut-off speed of 120 km / h and strays, shows 230 km / h at a speed of 120 km / h. The same problem with the ABS sensor rear axle. He's why I've got one, RV sensors are not installed..Is this correct? EPC shows that they are, but even on the semiaxes no incisions to read ... If assistance is required, I will give VIN. Thank you!
Sorry for my English curve, I use a translator.
My machine is the link :smile: Mercedes-Benz SLK ?????
SLK is R170, not w170
Please update your vehicle (year?: 1996-2015,) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘vehicle’. Your profile is NOT updated in your ‘personal garage’.
Premium Member 2004 SLK200K
You may find the unit you have put in is from an automatic car (hence the small change in the reference) , which is more than likely your problem as the ABS units are different although apparently the same .
Discussion Starter · #4 ·
I apologize for the inconvenience prichenennye. I find it hard to navigate ...
I am trying to understand 0:)
You're doing great! Post an intro so we can welcome you properly :D
Discussion Starter · #6 ·
Welcome from Madrid ...
You want to say that the unit is a A0225450432 machine that has an automatic transmission? Even before the unit A0225450432, A0195453132 I bought the unit, and it was the same, only star diagnostic showed more mistakes ... For example, a block of 0432 roof swears on the ABS sensor in the gearbox, and the block 3132, and swears on the roof limit switches, and ABS sensors on all ....
Discussion Starter · #7 ·
Discussion Starter · #9 ·
I would try and mount a unit with the exact same reference to avoid problems ...
I would love it to be changed to be, but in Russia, I have not found. I tried to look at the United Arab Emirates - nepoluchilos. Its not working, I put in for repair, but there are 50 to 50 ...
I already cry from the heart ...: Хмуриться:
1 - 12 of 12 Posts
