1 - 12 of 12 Posts
a friend of mine runs an independent garage. He has a pre-facelift 230K which has been here for a couple of weeks and he can't find a solution to the problem.
The car won't change out of 1st gear.
Transmission fluid and filter have been changed.
Any ideas, please?
moving your post from r172 to r170 general discussion
Because you are a caring friend and was so concerned with his problem you were blinded by the light?
Registered 2009 SLK200
Engine mounts will have nothing to do with why you only have 1st gear and reverse .
Car is in limp mode !!!
V good diagnostic equipment needs to be pluged in extract codes .
Poss electro plate at fault etc !?!?
1 - 12 of 12 Posts
