Hi
I have 2005 MB SLK350 AUTO
Two days ago I valet my car and the guy turn on the headlight and I never switch back to Auto and yesterday I found my battery died..so I jumped but late to work so didn't have time to run it for long time...
However after this incident, when I start the ignition everything seems works fine however after less than 5 min my passenger side window and retractable roof does not works...
My friend said it's happening because electric system automatically converted to safe-mode or something after jumping the battery so I need to find out the way to unlock and convert the system to regular mode from the safe-mode.
Did anyone had similar experience? or know how to fix the system and make my passenger side window and roof working properly again?
If you know how to reprogram please explain in detail how to fix it. Please help me you can reply back to this message or email ([email protected]) me.
For the windows - put the window down, then hold the button to close it. When it is fully closed, continue holding the button for 2-3 seconds. Repeat for each window.
For the roof - turn key to position II then move and hold the roof switch in direction 3 until the roof is raised at the rear and continue to hold for 1 more second.
youngmokee,
Thank you,
Moderator/Founding Member
Time to invest in a battery trickle charger and do the pre-wire.
Reactions: JonB
