1 - 11 of 11 Posts
· *Registered
2012 SLK250/2000 SLK320
Hi Guys,
I have just bought a 2000 R170 SLK320, and it when I am in Drive, if I push it to the left, it does not go in to manual mode. It shows a 4 on the dash, then goes immediately back D. Any ideas what might cause this problem?
Sent from my SM-A725F using Tapatalk
· *Premium Member
2001 SLK200K/2001 SLK320
I have just bought a 2000 R170 SLK320, and it when I am in Drive, if I push it to the left, it does not go in to manual mode. It shows a 4 on the dash..
That is manually selecting 4th, push it left (-) again and it'll go into 3rd but will not hold the selected gear if you overrev the engine i.e. mine will do about 85mph in 3rd before it changes up to 4th by itself
.. then goes immediately back D. Any ideas what might cause this problem?
Might have to call in our resident guru @Dave2302 but is "W" or "S" selected? Seriously doubt that you're overrevving in 4th 🙃
· *Premium Member
So we agree it is not manual (like manual gearbox) it is a limiter up to selected gear and that will be ignored when one's foot reaches the carpet?
Yes, if you're in say Manual 3rd, flooring the pedal will scoot you up to the tacho redline @ 6k revs (rather than bringing in the kickdown which it will do if you're in "D") and will then change up whether you want it to or not. I tried to hit the ton in mine and it wouldn't have it in 3rd because it insists on upchanging to 4th thus depriving me of 5secs or so whilst it sorts itself out :ROFLMAO:
I suppose you could call it a semi-manual gearbox? Inasmuch that you can do whatever you want with the tip-tronic and if the car agrees with you, that's fine, if it disagrees with you it's self-protecting🙃
The Manual 'boxed 200 of mine on the other hand is self-protected by a fuel interrupt @ 6200rpm and is really easy to hit during spirited overtaking manoeuvres ~ I do believe that the V6 also has this feature but let's be right, you're not going to hit it with the 722.6 'box
Quite why @bullyboy112 's is going immediately back to D from 4th still remains a mystery :unsure:
· *Registered
Discussion Starter · #6 ·
Hi its a new purchase SLK320. When I pull the auto box down to drive. There is a + - and if I click it to the left it shows gear for, but almost instantly goes back to D. I have it on sport mode when trying this. Apologies, I did have a SLK230 before. Thanks for all your comments and help
· **Premium Member '02 R170 SLK V8 5.0 & '00 SLK320
Pure guesstimate as I would need to verify with TCU Data on SDS, but I'd say your Shifter has a defective microswitch, i.e. stuck in + all the time, hitting - makes it go down but as soon as you release Shift Lever it pops back to D as the + side is stuck.
· *Registered
Discussion Starter · #11 ·
Thank you that makes sense
1 - 11 of 11 Posts
