1 - 12 of 12 Posts
Founding Member 2006
suggest you only do 1 and then test before doing the other
Discussion Starter · #8 ·
fitted smart top and power converter today and so far no issues so all good on a wow note the piecha power converter is awesome if you havnt got one get one massive difference power is instant no more lag and as got to be the first mod you do before anything else:rockon::rockon:
Ok forgive my ignorance please. But I have to ask, what is a piecha power converter?
similar to sprint booster
Sprint Booster modifies the signal between the accelerator pedal module and the electronic throttle body. This modified signal forces the throttle body to open 'more' than the stock signal at a given pedal position. In effect, the idle-to-full-throttle pedal travel is reduced. This makes your car 'feel' more powerful because a given pedal input produces greater throttle opening. This is especially evident in the low to mid rpm range where most cars spend their time on the street.
1 - 12 of 12 Posts
