1 - 8 of 8 Posts
Hello
I hope you can help as I am now panicking a bit.
I had a problem with my passenger door not locking/unlocking with the key and button inside. Also the wing mirror glass wouldn't adjust either.
I had removed the door control unit and cleaning up the contacts inside it and everything works apart from when I close the door the glass doesn't move up the 5mm it is supposed to. It worked before.
Does anyone have any advice?
Peter
Founding Member 2006
Discussion Starter · #3 ·
Thank you for replying
I have just tried that, however it closes fully once after everything has been disconnected, and I try pressing the closer button again then it immediately opens that extra 5mm. Then I can do it again.
Do I have to do both windows at the same time.
Peter
no, you do not have to do both windows at the same time
check the procedure in your owner's manual as above
if still does not work
disconnect the battery (neg cable) for a minimum of 30 mins
reconnect
synch again and reset clock
try windows
Discussion Starter · #5 ·
Hi Jeff
I have good news :) I have stopped panicking.
When i tried it for the 4th time, i disabled the smarttop. I think this helped as it now closes when i close the door.
I initially didn't think it worked as i didn't have the plastic trim on around the catch, so it wasn't pressing the close switch. When i pressed the switch the windows closed :)
I am going to have a beer now.
Thank you for your help
Peter
Peter! That's great. If I had known you had the SmartTop, I would have mentioned that.
Discussion Starter · #7 ·
You weren't too know. It only dawned on me when I was try to synchronise the windows and I thought the system must be trying to learn the end points for the window travel. I then thought that maybe the smarttop was interfering with the messages, It was. I guess this is the reason you need to disable it when the car goes to the mechanics.
more so that they do not one touch the roof button and it starts opening or closing and might hit something if, let's say, it is up on a lift
1 - 8 of 8 Posts
