Hi
I removed the glovebox on my SLK55 AMG to effect a repair on the stupid vinyl ungluing problem.
During that process I disconnected the passenger airbag that resides on the glovebox assembly.
After repair I assembled all with no problem EXCEPT I now have a warning re that airbag. How do I reset the light? Is there a fuse that may have been blown? Pretty sure I didnt damage anything (although I obviously did !)
You may well get away with a 30min battery disconnect.
This sometimes resets a variety of components.
Remember to adjust clock and reset windows afterwards.
@i860
@VII7
Registered 2012 SLK350
That is a non volatile fault, you will need to use MB diagnostic equipment (or equivalent but NOT an OBD scanner) to clear it.
