Passenger side hot, driver side ok.
1314 Views 1 Reply 2 Participants Last post by  jbanks15
I have a 2000 SLK320, which is a pleasure to drive.
But the passenger airvent seem to be stuck on hot,
while the driver side is working fine, cold & hot.
I did find some info on the side about the duo valve, which I have checked and seems to be in order.
the 3 wires which feed this component has 13.5V on wires 2-3 but nothing on wires 1-2 (I assumed that the duo valve is controlled seperatly)??
One of the valves seem to be staying warm, while the other is working according to the contollers.
I have replaced the duo-temperature sensor, which is behind the radio, and supposedly provides temparate information for driver-and passenger side.
I am not out of idea's.
Could someone tell me what Voltage the duo-valve should have?
somehow I expect, 13.5V between wire 1 and 2 and 13.5V between 2 and 3, thinking 2 is neutral.
or any other idea's would be great.
1 - 2 of 2 Posts
Please update your location/vehicle (model and yr) in your profile as it helps the members answer any questions you might have based on locale and model and year.
Usercp at the top of page, edit your details, location/vehicle.
If you haven’t, please post an introduction in the ‘new members introduce yourself here’ section.
Thank you,
Sergeant-at Arms
See less See more
1 - 2 of 2 Posts
