1 - 15 of 15 Posts
Please can someone supply the part number for the steering angle position sensor for my r171 200 Kompressor vin number WDB1714422F029933 7. Regards Dave.
Let me see if i can dig that up
Discussion Starter · #3 ·
Thank you. I have an intermittent esp fault. I have cleared the codes on the ECU. Had the car 4 wheel laser tracked. I few steering sensors have appeared on ebay so I would like to buy one to eliminate that part of the system. Thank you Dave.
Datacard also
a lot of position sensor parts
Discussion Starter · #5 ·
Sorry but that sensor cannot be found on that document is it called something else. It is the sensor that measures the steering angle within the steering wheel. Is there a diagram with the parts on? Regards Dave
neither of your part numbers are located in epc
maybe another member can supply the missing words as to what it is called
Discussion Starter · #9 ·
Do you have the diagram for the steering wheel or steering column. The sensor is located behind the air bag? Also found another sensor 171 545 12 32 any good? All the sensor for SLK r171 start 171 545 _ _ _ _.
your previous parts from ebay do not show in epc.
yes that part works
replaced by 1432 called control unit...then it says steering angle :D
part 40....
Thats the one - the clockspring ..
1 - 15 of 15 Posts
