Anyone know the part number for this little "trunk pad" or whatever it's called?
It's on the R170's trunk, rear upper portion. It looks like it touches a pair of pads on the lid when it is closed.
Seems to be different orientations for left and right.
This is what it looks like removed from left side
Mine needs replacement as the rubber casing has come apart and fallen off. The part itself has no part number on it. I have looked on part diagrams but unable to tell for sure which one it is... the best I can tell is maybe #7 in the diagram, which is described as "Trim Panel Retainer"
got your vin Jae?
:eek:fftopic: Had a little giggle to myself when I saw the OP. In the UK 'trunks' are what you wear to go swimming ! (sorry...carry on and pretend I'm not here. I'll fetch me coat)
PS: OP hope you find the answer your looking for.
I think it is called a stop part 140
part number in pdf. this is from a 230 since i did not have your vin
  • Image uploading. Refresh page to view
yes that's it! thanks.
$11 each... not bad but not cheap considering what they are.
