read here @Sneaky Pete
You have a FL R171. So unless you have the separate HK amplifier (check your datacard) you have no need for any fiber optic thingy. If you remove your old radio the entire fiber optic stuff becomes redundant. Think your installer confuses your FL car with a pre-FL car. With a pre-FL car you could opt to keep the speakers connected to the AGW in the passenger footwell. In your case the AGW is in the HU. Remove that and there is no AGW,hence no operational fiber.Im installing a pioneer aftermarket radio into my R171. I called a place to get a quote on how much install would be and they mentioned I need a something about “fiber obtic” for the radio install. Im wondering what that is and where I could get it. Any links or brand recommendations would be great.
Attached below are the parts i bought. Let me know if I need anything else.
what would a separate HK amplifier be labeled as?You have a FL R171. So unless you have the separate HK amplifier (check your datacard) you have no need for any fiber optic thingy. If you remove your old radio the entire fiber optic stuff becomes redundant. Think your installer confuses your FL car with a pre-FL car. With a pre-FL car you could opt to keep the speakers connected to the AGW in the passenger footwell. In your case the AGW is in the HU. Remove that and there is no AGW,hence no operational fiber.
I don't know exactly. Something like "Premium Sound System" with an option code of 810 (at least here in Europe).what would a separate HK amplifier be labeled as?
just to clarify, I do have HK "Premium Sound System" but since I have a facelift (2009) SLK r171, I don't need to purchase a fiber optic decoder box? SO will I have to buy a separate amp or anything?You have a FL R171. So unless you have the separate HK amplifier (check your datacard) you have no need for any fiber optic thingy. If you remove your old radio the entire fiber optic stuff becomes redundant. Think your installer confuses your FL car with a pre-FL car. With a pre-FL car you could opt to keep the speakers connected to the AGW in the passenger footwell. In your case the AGW is in the HU. Remove that and there is no AGW,hence no operational fiber.
No,let me clarify.just to clarify, I do have HK "Premium Sound System" but since I have a facelift (2009) SLK r171, I don't need to purchase a fiber optic decoder box? SO will I have to buy a separate amp or anything?
Keep in mind that USUALLY (not always, but it is fairly common with certain amps, not sure about HK) the impedance of speakers are TWO ohms instead of the common (in cars!) FOUR ohms. Home stereo systems have (usually? always?) EIGHT ohm speakers..Rewire the speakers to your new radio HU in the dashboard.
Mwah, I would not worry to much about speaker impedance. It is no more than an average. Typical speaker impedance behaviour chart of a 6 ohm rated speaker :Keep in mind that USUALLY (not always, but it is fairly common with certain amps, not sure about HK) the impedance of speakers are TWO ohms instead of the common (in cars!) FOUR ohms. Home stereo systems have (usually? always?) EIGHT ohm speakers..
If you drive two ohm speakers in a system (HU) made for four ohms, you can burn the built in amplifier.. Same if you run higher ohm speakers (home stereo speakers for examples)..
