Indeed, you messed up something in the wiring to the sensors, or you got a faulty sensor. But given what you've done, I put my money on the wiring.
go on ebay there not oem but as good as £49 for a set of 4 or about £12 for1 4X MERCEDES A C E CL CLK SLK M R ML GL SL SLK CLASS PDC PARKING SENSOR 4PS1101S | eBayI have the same sort of problem with mine.
All the l.e.d. on the front left side display are usually lit up with a solid tone. I'm hoping it is just a bad sensor, which are about £60 from the dealers.
thanks for that but isn't there a main box the sensors plug in toyou mean fuse locations?
9 and 37
driver's side console and rear
http://www.slkworld.com/slk-r171-class-diy/187817-r171-fuse-relay-locations-pics-descriptions.html
thats the one thanksShould be in the trunk at the right side.
the problem is I get the same two red lights and buzzer on the front and back when I put it in drive and reverse so looks like star is the way to goI had 1 frontsensor failing and got the same error on the display as you got. If you only get the error when you put it in reverse then I would say at least 1 of your rear sensors is failing. STAR can pinpoint exactly which sensor(s) is/are failing.
So off to the dealer or simply replace all 4 with the set you found on ebay.
the fault is still there mateIf the parktronic fault is not present when you go for star it will be a waste as star does not store this as a a fault.
