1 - 10 of 10 Posts
* Registered
2009-Mercedes-SLK300
Hi All:
Work continues on my ‘new ride’. When purchased it did not have either of the parcel deck flaps. I was able to find replacement units but one came without that spring (will attack image). I have tried researching but unable to locate anything, not sure what it is actually called or even available as a stand alone part. Any assist appreciated.
597706
we don't have your vin to get part numbers
* Registered
Discussion Starter · #4 ·
Ok, Spoke too soon on my ‘Spoke too soon’. I only see a prior posting you gave to another person but no part number for what I need, only an item number of 200. My VIN is WDBWK54F19F191856. Thanks Jeff.
RtR
Standby....
Here is datacard first
Standby for part number
called pull rod item 200
  • 200
    A 171 790 01 59
    PULL ROD
    DRIVE FOR LEFT SIDE FLAP
    Quantity: 1
  • 200
    A 171 790 02 59
    PULL ROD
    DRIVE FOR RIGHT SIDE FLAP
597710
* Registered
Discussion Starter · #9 ·
got the push-rod-springs in, found out they did not come with the keepers so ordered them also, finally have all the parts ! Put the roof in the service position, shelf vertical. Started to fit my drivers side flap spring-arm to the pivot point on the bottom of the parcel rack, fit seems to be fine but noticed I have no hardware to keep the spring arm in place. Looks like it may have been a ‘C’ clip and a slotted washer combination, these were completely missing when I purchased. I can supply picture if needed but if someone has a diagram of how the flap is physically secured to the parcel deck would be great.
Appears to be only two points of attachment, the push-rod-spring and the arm that actually supports the flap.
Many Thanks,
Carl LaFong
  • 200
    A 171 790 01 59
    PULL ROD
    Quantity: 1
  • 200
    A 171 790 02 59
    PULL ROD
* Registered
Discussion Starter · #10 ·
To follow up. These parts were missing and I am piecing together. With the help of the group I am just about there. Here are two diagrams of pieces I am trying to attach.
I can see no listing for what secures this part to the Parcel deck. From looking at it my guess would be some C clip and a spring washer, the washer may be slotted.
VIN: WDB1714541F191856
Many Thanks,
Carl
1 - 10 of 10 Posts
