I just got a 1999 home, it seems to me the car is not going into overdrive.
rpm is 3000 at 60 mph.
any swithches or checks i can do?
thanks in advance
zxmzrc,
Thank you,
Moderator/Founding Member
I'm assuming it's an automatic with the 722.6 5 speed? 3000 RPMs isn't that far off from where my C230 is at 60 MPH. Just a thought, was the selector in 4 and not D? It's easy to to miss D and just drive in 4. Also, try and reset the adaptive transmission. I know there are instructions on the 202 and 210 forum on Benzworld, someone here will probably post a link from the 170 section of this forum.
