Vendor
Features & Benefits
We've done countless hours of extensive research, development and testing to bring to high-end roadster owners the best quality, most precisely designed and most awesome looking wind deflecting devices on the market.
Our Wind Restrictor is an amazing, unique and durable product that blocks as much, if not more, wind turbulence than the factory OEM mesh net windscreens and helps to maintain the temperature inside of your roadster when the top is down. All of the Wind Restrictors™ we offer can remain in place with the roof closed and are mounted solid yet inconspicuously without any permanent alterations to your roadster.
Personalize your roadster with laser etched graphics of your own design or choose from our stock graphics.
The "must have" for all Pontiac Solstice, Saturn SKY, Mercedes-Benz SLK 170 & 171 , Opel GT, Honda S2000, and Chrysler Crossfire. Soon to come; Wind Restrictor™ for Porsche Boxster, Audi TT, Mazda Miata MX-5, Chevrolet SSR, Cadillac XLR, BMW Z3 & Z4 and other fine roadsters.
Some benefits of the Illuminated Wind Restrictor™...
1. Eliminate most wind turbulence and wind noise
2. Personalize your roadster with illuminated graphics
3. Advertise your business with an etched logo
4. Can be wired to brake lamps, fog lamps etc.
5. Prevent unrelenting wind buffeting and driver fatigue
6. Carry on conversations with your passenger without raising your voice
7. Arrive with your hair in place and free of tangles, especially long hair
8. Enjoy more of the full richness and clarity of your stereo
9. Help maintain the temperature in your roadster when top is down
10. Each order includes spray cleaner, cotton gloves or other accessories
The only wind deflecting device to have all these features...
*Made from double-sided AR Polycarbonate.
(Very durable acrylic type material is also scratch resistant! Others are made out of much cheaper materials and dangerously breakable plastics. Some may be made out of Lexan; the disadvantage to Lexan is that it scratches easily and won't emit illumination, It may also discolor with etching.)
*Professionally precisely designed and laser cut.
(Others are produced at home using table routers and jigsaws leaving rough edges and defective shapes. Wind Restrictors™ are professionally produced from the finest materials using state-of-the-art equipment.)
*Can order with ILLUMINATION.
(The only wind deflecting device on the market that has this patent pending feature! You can have the Wind Restrictor™ Light Kit hard wired to any 12 volt wire of your roadster, e.g. fog lamps, brake lights, driving lights, etc. Most car audio/electronic shops or dealerships can wire it or you can do it your self in less than 1 hour. A cigarette lighter plug adapter or AAA battery pack can be added for an easy, convenient connection.)
*Can order Laser engraving.
(Etched with a high powered laser to really make your roadster unique and stand out. The engraving will also emit light and give off an awesome glowing effect with a Light Kit installed. personalize your roadster with a custom logo or stock graphics.)
*PERFECTLY formed to the contours of your roadster.
(Others are not designed and manufactured to exactly fit the bodylines or roll bars on your roadster.)
*Attaches to your roadster without permanent alteration or tacky fixtures.
(No drilling of holes, adhesive tape, Velcro or straps.)
*Extremely smooth crystal-clear edges.
(Others are sometimes sharp and ridged, ours are laser cut smooth to perfection then flame polished so that the Wind Restrictor™ looks and feels like a million bucks as well as emitting illumination to the fullest.)
*Installation easy as 1,2,3!
(1.- Remove 2-4 screws from your rear panel; 2.- Mount the Wind Restrictor™ into place; 3.- Put extended screw connectors back in place! takes about 5-8 minutes.)
All of this plus your forum discount using discount code Paul
Check us out here!
