1 - 20 of 22 Posts
* Premium Member
SLK 200 R172 2011 🇮🇹
Sometimes I get the open bonnet red signal on the car dash also when the hood is closed.
It happens randomly. I am aware that there it should be a bonnet open/close sensor beneath the driver sides (LHD) front latch. I believe that the sensor may be defective or needs some contact cleaning or lubrication. Any tips regarding that sensor, could not find the specific issue regarding the sensor on other threads, found something similar but was related to hood malfunction which I believe is a different issue. There is aspecific maintenance to be done? I tried to remove the latch but cannot get beneath it...should I detach the hood latch were it divides in two at the Y?
Any help is appreciated.
592103
* Premium Member
Is there any 'give' when the hood is shut? It may be that the stops/support buffers need adjustment.
I'm sure we had a similar question a few weeks ago.
@Windinmyhair thanks!
I have to recheck that, possibly slightly on one side...should it be tight and not give a little?
Can the spring buffers be adjusted?
* Registered
2012 SLK 250CDI
We did indeed!
* Registered
2012 SLK 250CDI
Any help is appreciated. View attachment 592103
There is a micro switch underneath one of the hood catches, difficult to see but if you open the hood and carefully push in the catch you should hear it click it it is working. On my UK car it is the catch on the driver's side. Will put up a picture in a few minutes.
* Registered
2012 SLK 250CDI
The microswitch is just below the coiled spring in this image
* Premium Member
@DavidD Thanks!
I had all the latches and joints lubricated and checked as per the other post already...there is a minor hood movement when closed but it seems reasonable, my doubt was that one of the switches was faulty or dirty so I wanted to try to clean it or clean the connectors, but as I can see possibly the area can be cleaned directly without detaching the all latch....
Could not also understand if that microswitch was mechanical or had an electronic contact...
* Registered
2012 SLK 250CDI
The microswitch has wires connected to it, it tells the car if the hood is open or closed, if the switch is dirty and/or faulty it will give you the problem that you are experiencing.
I would recommend trying to clean the switch and also check the wiring as much as possible for any damage or shorts. I guess if you remove the 2 bolts it SHOULD lift off but I have never done that!
Super Moderator (UK)
If you can avoid dismantling first I'd go that way.
I saw the data sheet for bonnet adjustment years back (171) and was mortified by how many adjustments there were.
The two stops are worth looking at too (mark before adjusting so you can return them to where they started).
Has the car had any bodywork/paintwork done on the front?
I'm just wondering if it has, whether the technician got everything back to normal.
* Premium Member
I removed the two screws that hold the lock in place although I was unable to lift it from the hole, I will try to push it back posteriorly to see if I can access it from the posterior side...
* Premium Member
Car is as original no work done on it....it has 110k km by the way so something may have loosen up
* Premium Member
@Windinmyhair @Avel Du @DavidD @jbanks15
We might have something here...
By the way I could not understand the thread very well...I might need an engineer....LOL
* Registered
2012 SLK 250CDI
That does sound somewhat complex! Sounds like there are very small tolerances with the locking mechanism and switches, any build up of dirt might cause a problem, you could try a good clean with something like wd40 to remove any build up of dirt. If you do that you will also need to lube it afterwards as wd40 and the like will also remove oil as well as dirt!
* Premium Member
Discussion Starter #15 (Edited)
I'll try to clean the area...
By the way I have taken from the web those pics which match with part 320 and 130 from the drawing. This ones are very dirty indeed...
592110
592112
592113
592114
592115
592116
592117
592118
592119
part 110 and 120 in this drawing....
* Premium Member
Discussion Starter #17
I think I got the issue sorted...
The R172 aluminum bonnet flexes quite a bit compared to other more "heavy" hoods, therefore when closing it engages the central latch, but it might not engage the lateral ones or at least it engages one and not the other...
I tried several times and found that the side which does not engage properly it moves a bit and is easily identifiable, is just a matter of pressing on that side over the latch area so to make it engage.
There is a circuit that closes when the two lateral latches are in the closed position so to give the ECU the "closed hood" signal.
I have seen in a similar thread that someone was slamming the hood harder when the "open hood" signal would come up on dash, to sort this out...I suggest not to slam but just press on the loose lateral anterior bonnet side, in order to resolve the open hood signal, and avoid slamming which may damage latches or the hood components.
@jbanks15 @Avel Du
I believe is SORTED...but will keep posted if it happens again to exclude any other reasons for this problem...
Super Moderator (Canada)
2012 SLK55 AMG w/P30 "Schwarzie"
We'll mark this resolved but as you said, if the problem returns, come back to THIS thread (do not create a new one) and we'll update accordingly (y)
Premium Member 2014 SLK200
From the Owner manual:
Closing the bonnet
Lower the bonnet and let it fall from a height of approximately 20 cm.
Check that the bonnet has engaged properly.
If the bonnet can be raised slightly, it is not properly engaged. Open it again and close it with a little more force.
* Premium Member
Discussion Starter #20
Closing the bonnet
@Windinmyhair my personal opinion is not to let it fall but to close it and push gently, but is just my personal view...
1 - 20 of 22 Posts
