I have removed my K40 as I want to redo some soldering. I disconnected the battery negative before removing the K40 relay and now I would like to reconnect power to have the central lock and alarm functioning. Is it ok to reconnect the battery while the K40 is out?
Thanks!
Raindog
Thanks Livefree. I was not planning to try and start the car or even turn the key in any way - just connect the battery. Could battery connection alone set codes?
